carb's from rick west!
1 red zl9 Nov 10, 2012
  1. 1 red zl9
    1 red zl9 Well-Known Member
    1,157
    :D finnally got my new airbox boots 2 day, put those on and yes markus u were rite about new being so much easier. it took me over an hour with a few choice words just 2 get # 3 on and that's went i went inside 2 order 1 2 and 4, what a difference those new one's made. put on tank with new pingle and uni air fiter, buttoned everthing up opened the fuel valve, seen no leaks. turned on the ignition, crossed my finger's and BINGO! didn't even choke it and it fired up after 5 seconds of cranking idiling just ass smooth as a baby's ass. took it 4 just a quick spin around the block and it run's better then ever! if anybody ever want's there carb's done send them 2 oldskool carbs, he is the best when it comes 2 how they run and look! my hat's off 2 him. now i just wish i had some warmer weather 2 go open that bad boy up which im sure there's probably a few day's left but there's nothing like summer cruising on a well running ZL9!!!! DAMM I'M FRICKIN HAPPY!:D:D:D:D :cool:
  2. zlMark
    zlMark Cult Leader
    8,935
    235
    121
    Noice! Great feeling when hard work and $$ spent pays off! Enjoy!
  3. markus56
    3,459
    218
    Congrats Bro..........nothing like that feeling of accomplishment!!:notworthy: :thumbsup:
  4. madmanncr500
    madmanncr500 Senior Member
    5,521
    124
    108
    :thumbsup:
  5. CHRIS
    4,659
    21
    Congrats Bro !!!
  6. 1 red zl9
    1,157
    had the time after work yesterday 2 open up the throttle on my local parkway, (local test track):laughing7: and what a difference in smothness and accelarating! no problem starving 4 fuel at 9 ounces per minute hence the pingle, nice piece. carb's from rick. pingle, uni air filter,3 new air duct's cuz there was no way # 3 was coming back off after what i went trough 2 get it on:angryfire: seemed like i needed 2 hold on 2 the grip's a little tighter:laughing7: but that's what i was looking 4 in the first place! luv them big zl's speed shifting at 10 grand. what a rush!:HappyFacePuttFrnt7K
  7. madmanncr500
    5,521
    124
    108
    :thumbsup: ALWAYS GOOD TO GET OUT AND CRACK THE THROTTLE OPEN!!!!!:headbang:
  8. JR1337
    JR1337 Active Member
    332
    YEp, I might send mine his way if I cant sort them out myself, they are leaking gas. Hopefully just needs float height adjusted.
  9. 1 red zl9
    1,157
    do yourself a favor and send 2 oldskool! and by the way my parent's live in hartwood va.:laughing7:
  10. JR1337
    332
    That will be my last resort, because I KNOW Rick will do them right and I wont have any more trouble with them. But I want to try, because I would prefer to be completely self reliant. When the zombie Apocalypse comes, and its just me, my shotgun, and my zl, I wont be able to send them off to Rick ;)
  11. zlMark
    zlMark Cult Leader
    8,935
    235
    121
    Hang in there JR. I will be doing a carb doc with pics real soon. I have them all tore apart on the dining room table now and pics this far. Just need to snap a few pics of cleaning and then write up the doc. meanwhile get yourself some JIS screwdrivers :thumbsup:
  12. JR1337
    332
    Cant wait!, I took em all down no problem without the JIS drivers, but I also have an assload of different screwdrivers because I work on lots of electronics.
  13. jhawkins
    jhawkins Member
    9
    Hi
    I found the settings that you (zlMark) said to put them at in the ZL900 stock jetting specs. This is what i have in now. This is the way i got it.
    The only way i can get her to start is to use starter fluid then she will start with no prob.When i give her some gas she bogs down then gets up and goes.
    Any help would be great.
    P.S. ZlMark don't know if you rember me or not. I was in Ohio with Jim (jgonzo) I had the red Vulcan Vaquero.
    Pilot jet #40
    Needle clip position not adjustable with factory parts (unless shimming)
    Main jet #125
    Air Screws 2 1/8 turns out
    Float height 17mm + or - .5mm
  14. jhawkins
    jhawkins Member
    9
    It does not seem like it does anything when i use the choke.
  15. salamander
    salamander Active Member
    490
    That sounds like nothing even close to right. When you move the choke lever, does the slide at the carbs move (ie, broken cable, or incorrect cable tension)? If the cable seems to control the slide ok, you may have blocked lines in the carbs that are supposed to run extra fuel when the choke's on -- but that would mean all of them are blocked ... seems unlikely.
  16. jhawkins
    jhawkins Member
    9
    I took the carbs apart tonight. I am cleaning the needles and going to blow some air in the line to see if that helps.
  17. zlMark
    zlMark Cult Leader
    8,935
    235
    121
    Hang tight and have a look at my tech doc in progress on carbs. I'll try to get it on by the weekend
  18. salamander
    490
    +1 on waiting for the tech doc. I followed a written description zlMark gave on carb cleaning and everything worked out really well.
  19. Scoobys_piece
    2,026
    I too, would love to know how carbs work and not take the easy way out. It is SOOOOOO good to have someone that will invest the time to document these frisky lil bears.
  20. wickedzl900
    wickedzl900 Senior Member Supporting Member
    393
    34
    123
    thanks for the kind words,,, rick
