CARB CLEANING SERVICE ,ultrasonic cleaning
wickedzl900 Nov 15, 2007
  1. wickedzl900
    wickedzl900 Senior Member Supporting Member
    357
    21
    113
    normally not, just air pod filters
    7,744
    283
    :hello: What kind of exhaust. I have Slip on 10 inch Supertrapps & no jetting was needed.
  3. PTPopz813
    PTPopz813 Member
    57
    The pipe (x pipe?) Under the transmition is rotten. I am going to weld up a stainless Xpipe at work and replace the resonators with new aftermarket ones... Still a couple of months down the road.
    7,744
    283
    :hello: If you are not running pods you won't need to rejet your carbs.
  5. Ducky Dog
    Ducky Dog Active Member
    177
    20
    A little update on my ZL9 carbs that Rick rebuilt
    First off,, lately I haven't been riding much due to work load
    But,, I was able to get a few rides in ,,,,
    My first ride was a 50 mile round trip on the freeway, traffic was paced at about 90 mph.
    That was a bit high paced to do a fuel/mileage check but it is knowledge gained
    The bike ran smooth as silk and always had more rpm on tap.
    the next two rides were short, in town, 5 miles each and of course the bike ran flawlessly
    I got about 61 miles then hit reserve. the last tank of gas I hit reserve at about 54 miles
    so my fuel efficiency is much better and I think if I stay under 70 mph I will get even better mileage
    last thing is the minor buzz at the gas cap is gone...
    Thanks again Rick,,, Job well done!
    I forgot to mention ,,, I nailed 2nd gear crossing an intersection and pulled a wheelie, Me happy!
  6. wickedzl900
    357
    21
    113
    thank you , Ken
  7. badbrad
    badbrad Senior Member
    1,024
    14
    123
    Rick, sent you a message my friend! I’m finally ready and 1 set of carbs is boxed and ready to go. I sent you my number, just give me a buzz and I’ll grab address and all again.
    I have got to stop letting these babies sit!
  8. markus56
    3,191
    134
    Same here Brad.....gotta' do my 9 again from letting it sit. I normally drain the carbs which is good enough but i DIDN'T THIS TIME. I'll be sending a set before much longer too Rick.
  9. Harriminator
    736
    119
    You become old... s126.gif . :laughing7:
  10. badbrad
    1,024
    14
    123
    I can’t believe I spent all the time getting these bikes right then let them sit. I had trouble with my low mileage red 900( you did the forks on this one) as it would crank and run good then within about 2 minutes it would start to run real rough and cut off. If you let it sit for about 5 minutes it would crank back up and run like new for about 2 minutes and would run bad and cut off again. I got aggravated and just let it sit.
    Well, I found the problem when I removed the carbs. The seat was pinching the supply line just enough to let it run for a couple minutes. I’m almost 100 percent sure it will run right now once I get the carbs done.
    The 1000 just sat to long too. I need to rebuild the water pump as it’s leaking oil . I just let it sit and now I have the carbs and water pump to rebuild. I will get it, I’m focused again, lol
  11. badbrad
    1,024
    14
    123
  12. badbrad
    1,024
    14
    123
    The ethanol gas today takes at least 4 months off of the sit time. I have a gas station nearby that sells non ethanol gas and will be the way I go from
    You still doing fuel valves? I’ll need to take a look at mine, May can just clean it up. They started to leak gas
    7,744
    283
  14. wickedzl900
    357
    21
    113
    brad let me know when you send them
  15. markus56
    3,191
    134
    Yeah Brad, I wished I had a non ethanol station around me that I could get good petrol at but I don't. Yes, I still do the fuel valves and have some ready to ship if anyone needs one for either the 900 or 1000.
  16. badbrad
    1,024
    14
    123
    Did you get the carbs?
    7,744
    283
    :hello: I pulled my carbs today on my ZL 10. I'm going to get the carbs bank rails & brackets powder coated. Also the float bowls need cleaned. I don't think any of the carbs bank rails, throttle cable holder, choke cable holder & such was not cleared. They are starting to rust._____________________ IMG_6822.JPG IMG_6831.JPG IMG_6830.JPG IMG_6827.JPG IMG_6832.JPG IMG_6833.JPG
  18. wickedzl900
    357
    21
    113
    still doing these
  19. badbrad
    1,024
    14
    123
    U F0F86DEF-0F73-47A5-968B-33C87B4CBA1A.jpeg You sure are still doing them! I forgot how sweet they are when you get done with them. Glad I got mine back from you today. The old ZL will breath new life in a couple days. It was nice meeting the man behind the curtain in person today, thanks Rick,
    you are truly the best when it comes to freshining up these carbs.
    R. J. and wickedzl900 like this.
  20. wickedzl900
    357
    21
    113
    badbrad SANY6166.jpg SANY6167.jpg SANY6169.jpg SANY6170.jpg SANY6171.jpg SANY6173.jpg SANY6175.jpg SANY6182.jpg SANY6183.jpg SANY6184.jpg SANY6185.jpg SANY6186.jpg SANY6187.jpg SANY6188.jpg SANY6189.jpg SANY6190.jpg SANY6194.jpg SANY6195.jpg SANY6196.jpg SANY6198.jpg
