86 zl 600 bobber
Richie Dec 12, 2018
  1. Richie
    Richie New Member
    Hey guys, I bought this bike 2 months ago from a guy here local, paid $200 for it, it will fire if you jump the solenoid, the PO decided to "fix" the wiring. So unless I can find a really good diagram, I'm probably going to start from scratch, I've done some paint work on it, and went through the carbs, cleaning, checking everything out, and synched them up, question I have is, can I just cap the vacuum inlets on the engine side of the carbs? If not, what goes where, I've got a aftermarket petcock,
  2. Richie
    Richie New Member
    7,822
    291
    :hello: Welcome to zl-oa. Nice pics. :notworthy:.
  4. 87kawzl
    87kawzl Senior Member
    1,390
    93
  5. furchin
    2,064
    43
    Check our down load section for the wiring diagram in the base manual. I think it's in there. As far as capping the vacuum ports, as long as the after market petcock is manual and not vacuum operated then yes you can cap them.
  6. Richie
    Richie New Member
    Dumb question but how do I know if it's a vacuum petcock or not? The one I bought only has the one line coming from it, so I take it it is manual? And am I good to pull all the smog/emission stuff out, it's located between the engine and the frame rail
  7. furchin
    2,064
    43
    Only one line would indicate it is manual, so you are correct. And yes you can remove the emission crap. Just make sure you either install block off plates on the reed valves or cap the outlet pipe with a plug. I used rubber furniture leg caps. They were either 5/8 or 3/4 inch, don't remember but somewhere on this site I do have the information if you look for it.
    Just checked my extra parts and the caps are 5/8, 16mm
  8. ColinG
    ColinG Active Member
    89
  9. Richie
    Richie New Member
    Thanks furchin, and ColinG, I think your thread was the first one I read on here lol, I disabled all the smog emission crap and she is running pretty decent , still have to fine tune everything, does anyone know a good way to attach leather to a steel seat pan? Only way I can think of is pop rivets and fender washers lol
  10. 87kawzl
    1,390
    93
    7,822
    291
  12. Richie
    Richie New Member
    Thanks guys, I'm going to use 3m 97 I got from work, we use it to stick gaskets to metal, I'll use it to attach the foam to the pan, then use it and pop rivets to attach the leather, I've got a whole dear hide I'm thinking of using, going to leave it natural I think
