1988 250 Eliminator
R. J. Oct 22, 2016
    552
    :hello: While the 250 is starting to look like a bike again. I got it back on the ground today. I polished the forks. It took 3 hours. I mounted the front fender & tire/wheel. I painted the front rotor & polished the rotor bolts. They looked like crap next to the shinny forks. Mounted the front new OEM turn signals & both mirrors which are new OEM. They are from the VN 750. The 250 ones are dicontinued. Last but not least the right foot peg mount with stand. I have Ron B coming over in the morning to help me put the air box to carbs boots on. He has long skinny fingers. :laughing7:. IMG_6334.JPG IMG_6337.JPG IMG_6340.JPG IMG_6342.JPG IMG_6343.JPG IMG_6344.JPG IMG_6345.JPG IMG_6346.JPG IMG_6348.JPG
    markus56 and W_L like this.
  2. W_L
    W_L New Member
    14
    Nope, you will have (or rather you should have) enough space just by moving the airbox all the way back. Although I suppose removing airbox entirely would add some extra work space.
    552
    :hello: OK: Thank's W L. I just hope that I don't have to go 12 rounds with the boots. :laughing7:.
    552
    :hello: Ron B came over at 9 AM to help with the boots. I undone the air box & took out the battery & slid it back about 2 inches. I went to take a dump & came back out to the garage & Ron already had the carb boots on. I dressed out some more of the wiring harness. Also the voltage regulator had to come out when doing the boots. The oil seals came in the mail today so I installed one in the water pump & reinstalled it. I installed the exhaust header. It was ceramic coated in cold steel. I went ahead & cleaned up the front sprocket. Also I mounted the head light bucket. I'm going to have to switch out 2 connectors in the head light wiring area & move some wires around. The 1994 wiring harness is different than the 1988. The reason why I changed wiring harnesses is so I can use the tach from a 1994 250. Tomorrow I'm going to mount the radiator, radiator shrouds & muffler. IMG_6349.JPG IMG_6350.JPG IMG_6351.JPG IMG_6352.JPG IMG_6355.JPG IMG_6356.JPG IMG_6357.JPG IMG_6360.JPG IMG_6362.JPG IMG_6353.JPG IMG_6354.JPG
    W_L likes this.
    552
    :hello: I didn't work on the 250 Fri. To wiped out from the heat. I've been getting up late & working late on the 250 to avoid the heat but still to hot out until about 9 PM. Today I put the oil in (20w-50 Amsoil). I cleaned out the clutch master cyn & blead the brakes. I use LUCAS synthetic brake fluid. Installed the radiator & the last 2 hoses along with the NOS OEM rad shrouds. I'm going to try ENG ICE coolant. Cleaned up the chain guard & mounted it. The 250 didn't come with a tool set. I couldn't find a set for the EL 250 so I bought one from an EX 250. Plenty of room in the tool tray for other things. Cleaned up the muffler & painted it just as KAW done. Also cleaned up the 3 heat shields. Painted the small black one the goes on the left side of the carbs. Mounted all 4 side coves & fitted the front seat. Not sure if I'm going to work on the 250 tomorrow or not. IMG_6368.JPG IMG_6365.JPG IMG_6364.JPG IMG_6363.JPG IMG_6371.JPG IMG_6377.JPG IMG_6370.JPG IMG_6374.JPG IMG_6375.JPG IMG_6376.JPG IMG_6378.JPG IMG_6379.JPG IMG_6380.JPG IMG_6382.JPG IMG_6383.JPG IMG_6384.JPG IMG_6385.JPG IMG_6386.JPG IMG_6387.JPG IMG_6388.JPG
    W_L likes this.
  6. Harriminator
    968
    218
    :hello:When bike ready you'll get new warranty by Kaw...:laughing7:. Great job!!!
    W_L likes this.
  7. markus56
    3,407
    199
    He sure should get a warranty from the factory....it's factory NOS!!!! You're trying to make me buy that thing aren't you R.J.?
    552
    :hello: Thank's guys. In the past 16 months I slowly bought parts, had paint & powder coating done. I paid $800 for the 250 & spent about $1460 on parts, paint & powder coating. I was out in the garage last night until 2 AM. It was only 80* in my garage with 2 fans going. I have to swap out the 3 connectors for the contols before I can start the bike. The Service Manual has 6 different schmatics for the 250. US/CANADA & 5 other Contries.
    552
    :hello: It was 78* in the garage tonight. I bought a lock set for a 1999 Drifter for the lower right side cover whick locks the tools in. The 250 is discontinued. Of course I had to modify it. I had to make a longer tab & put 4 spacers under it so that it would reach the latch stay. I used old brake cal crush washers for spacers. :laughing7:. I fabracated a bracket to mount the KOSO volt gauge & the DAYTONAMETERS temp gauge. I painted the bracket with VHT gray paint. The 1991-94 tach set up is turning out to be more involved than I anticipated. I had to buy both bar controls & instrument panel. The 88 250 has more wires in it than the 91/94. I got the right one in the mail today. I had to solder the 88 250 bar controls switches to the 94 harness. The other 2 parts will be here Thurs. IMG_6393.JPG IMG_6395.JPG IMG_6396.JPG IMG_6398.JPG IMG_6399.JPG IMG_6400.JPG IMG_6402.JPG IMG_6404.JPG IMG_6401.JPG IMG_6406.JPG IMG_6407.JPG IMG_6409.JPG IMG_6410.JPG IMG_6417.JPG IMG_6416.JPG IMG_6418.JPG IMG_6419.JPG IMG_6420.JPG IMG_6421.JPG
    W_L and 87kawzl like this.
  10. 87kawzl
    254
    Nice soldier job RJ. It looks to be real close to road ready now. I'll bet you can't wait to pick a race, tell them "meet me @11 and I'll run ya on my eliminator for 5 hund" then show up on the big one!
    On a side note, you can re-use the copper crush washers on the banjo fittings if ya run them over some 150 sandpaper until they are smoothed out.
    552
    :hello: Thank's: I have 12 hours in making, painting & installing the home made lock tab & meter bracket.
    552
    :hello: DONE:occasion14:. IMG_6431.JPG IMG_6432.JPG IMG_6433.JPG IMG_6434.JPG IMG_6435.JPG IMG_6436.JPG IMG_6436.JPG IMG_6438.JPG IMG_6439.JPG IMG_6440.JPG IMG_6441.JPG IMG_6442.JPG IMG_6443.JPG IMG_6444.JPG IMG_6445.JPG
    W_L, kvalheim and Harriminator like this.
  13. markus56
    3,407
    199
    That little feller is just as slick as it could be! Great job R.J., you have the nicest one in the country now for sure! Have you had a chance to ride it yet?
    552
    :hello: Unfortunately no. :pain10:. I need a starter solenoid. It's shorted out & blows the 30 amp fuse. I had every sub assy. disconnected & it still blew the fuse. Also the ignition switch might need replaced. The wiring at the switch has 2 red leads for power for the 91 wiring harness & the 89 doesn't. I'll be bringing my ZL 10 to VMD.
  15. kvalheim
    kvalheim Well-Known Member
    631
    34
    Sure looks nice R.J. Hope your fix is a easy one.
    552
    :hello: Thank's guys. :notworthy:.
  17. Trojan441
    790
    97
    Right I would like to know where you get your parts from as no-one over here supplies Eliminator stuff as far as I know, I would need stuff for the two smaller 4'S..
    Many thanks
    john H
  18. R. J.
    552
    :hello: Mostly from E-bay. Some NOS parts from over seas, but most from KAW. Used if I can't buy new.
  19. kvalheim
    631
    34
    Did you get your problem solved yet R.J.:hello:
  20. R. J.
    552
    :hello: No I have not. I'm still in PA waiting on my truck to be fixed for the 4th time. :pain10:.
