1988 250 Eliminator
R. J. Oct 22, 2016
    552
    :hello: OK: I'll get a price for you when I pick up the 250 side covers & front fender.
    552
    :hello: MarkUS: Dave hasn't given me a price quote on painting as of yet. I'm going to see him today.
    markus56 likes this.
    552
    :hello: This morning I started to put all the 250 sub-parts together. (CLUTH COVER) New OEM parts. IMG_6247.JPG New oil site glass installed IMG_6248.JPG Used a 17 MM deepwell scoket. IMG_6249.JPG Polished shaft & pre-fit new needle bearing & oil seal IMG_6250.JPG Ready for install. IMG_6251.JPG Pushed bearing in with fingers. IMG_6252.JPG Used a 12 MM deepwell socket for bearing. IMG_6253.JPG Used 14 MM deepwell socket for the oil seal. IMG_6255.JPG Prefitt clutch engaging rod. IMG_6257.JPG IMG_6258.JPG The oil level site window was hard to get in. My powder coat guy did not plug it off before shooting it. Time spent 1 hour.
    552
    :hello: I assembled the speedo. & tach. The 250 has 1,195 original miles on it. IMG_6259.JPG Spare tach is on the left & the one I'm using is on the right. I replaced all hardware with SS. IMG_6262.JPG Powder coat is done in BMW silver. IMG_6265.JPG All new OEM dampers incluiding the big O-ring ones. IMG_6266.JPG I keep a stock of metric SS hardware on hand. IMG_6267.JPG I need a bigger table :laughing7:. IMG_6268.JPG The fork brace & the rear brake rod are done in BMW silver. IMG_6269.JPG IMG_6270.JPG Both foot peg assemblies are done in gloss black. IMG_6271.JPG Rear brake drum stay rod & both axles are BMW silver.
    552
    :hello: MarkUS: Dave wants to know if any body work needs done other than sand, prime & paint. If not it will be $150.
  6. markus56
    3,407
    199
    No body work needed on anything......just sand and paint. That's a good price....I will be getting back with you when I get the tank mounts repaired.
    552
    :hello: OK: MarkUS. It may be more if you want the underside of the tank painted. Today I did some work to the 250. Mounted upper tripple tree & forks. Fitted speedo & tack. Remounted rear fender & rear seat. I had the rear & front fenders painted again. I also mounted the handlebars. Spent about 2 hours wet sanding & hand buffing parts. I spent 3 freaking hours looking for parts & inventorying them. I put a small dent in clearing the table. :laughing7:. IMG_6288.JPG IMG_6289.JPG IMG_6290.JPG IMG_6291.JPG IMG_6286.JPG IMG_6287.JPG
    W_L likes this.
  8. 87kawzl
    254
    Looking great RJ, spent my morning screwing my ZL10 back together. A bit of spit and polish but nothing like you are having fun with :thumbsup:
    552
    :hello: Thank's. :notworthy:. I'm hoping to be done by Tuesday.
    552
    :hello: Today I got a few things done on the 250. I pulled the starter & painted it. Cleaned up the motor. Installed the 2012 EX 250 water pump. Installed the valve cover & the stator cover. Installed one coolant hose & two coolant pipes. I also painted the clutch perch & cleaned up the front brake master cyn. I was interrupted so much today it made my head spin. :laughing7:. It just sickens me to no end. IMG_6296.JPG IMG_6304.JPG IMG_6302.JPG IMG_6303.JPG IMG_6300.JPG IMG_6299.JPG IMG_6305.JPG IMG_6306.JPG IMG_6293.JPG IMG_6294.JPG IMG_6307.JPG No one listens to my WARNING label. :laughing7:.
    RLTherio likes this.
    552
    :hello: Happy Fathers Day to all you Dads. I didn't get much done on the 250 today. I have yet to put in a full day on this bike. I mounted the coils along with new spark plug caps, new plugs & new 7 MM copper core wire. The bike had the wrong plugs in it. Installed the clutch cover, right foot peg assembly, tire/rim, new chain, I also had the brake drum powder coated BMW silver along with the brake drum stay rod, brake rod, brake rod spring, adjusting nut & that gismo that the brake rod goes through which was all installed today. Installed the upper coolant hoses, thermostat housing & rad cap. I also put on new brake shoes. The old ones was starting to come apart at the edges. I've never seen that before. The parts that came off was really hard. Tomorrow I hope to get in 12 hours on the 250. IMG_6308.JPG IMG_6312.JPG IMG_6311.JPG IMG_6315.JPG IMG_6313.JPG IMG_6314.JPG
    W_L likes this.
  12. markus56
    3,407
    199
    You've sure got a nice looking project there R.J. You'll have the nicest one in existence when you're done!
    552
    :hello: Thank's MarkUS. I'm fed up with all the other FN crap that I have to do before I can work on the 250. :pain10:. I'm missing parts. :pain10:. I had to pull out the water pump because I forgot to put in the oil seal. :banghead: & I don't have one & the one I ordered won't be here until thus. Now I have to run to ACE & it's so FN hot in my garage. I've changed my soaked cloths 3 time today. I think next month I'm going to put a window in my garage so that I can put in one of those window A/C units.
    552
    :hello: While today I managed to get some work in on the 250. I installed all the controls along with new OEM levers, left new grip, new intake carb boots, NOS front brake line, NOS opening throttle cable, new clutch cable, headlight bracket & new exhaust header gaskets. Tomorrow I'm going to rebuild the front brake cal. & what ever else I can get done. I spent 4 hours today trying to find an oil seal for the water pump. IMG_6316.JPG IMG_6318.JPG IMG_6321.JPG IMG_6317.JPG IMG_6321.JPG IMG_6322.JPG IMG_6323.JPG IMG_6324.JPG
    87kawzl, W_L and markus56 like this.
  15. 87kawzl
    254
    RJ, make sure flat side of copper is toward the head on your exhaust gaskets.
    552
    :hello: Yes it is. Thank's.
    552
    :hello: While today was a bust. The only thing I did was rebuild the front brake cal. Also I mounted the carbs, hooked up the choke cable & throttle cables. I spent 5 hours trying to get the air box to carb boots on. It's super tight. I get the boot up in then it falls into the air box. No room to get your hand in the air box. It looks like the air box needs to come out in order to install the boots. I won't be able to do that until I get the bike back on the ground. IMG_6319.JPG IMG_6325.JPG IMG_6327.JPG IMG_6328.JPG IMG_6331.JPG IMG_6332.JPG IMG_6333.JPG
  18. W_L
    W_L New Member
    14
    First, let me say your making some motorcycle porn there ;) Bike looks astonishing. I mean, if they ever did deluxe version of EL250, it would look like this.
    Regarding the carbs installation without loosening the airbox you will not have enough space to maneuver the carbs to fit the outlets into the boots and you really need to push them hard while changing the angles to make it jump in into the place. I have reinstalled carbs in this model at least dozen times and it PITA every single time. Anyway, great job R.J.!
  19. R. J.
    552
    :hello: Thank's W L on both counts. :notworthy:. Last night I spent from 7 PM to midnight fighting with them intake boots. I have all new boots so it should be easier.
  20. R. J.
    552
    :hello: Do I need to remove the rear fender to slide back the air box.
