1039cc engine swap
madmanncr500 Aug 17, 2012
  1. Scoobys_piece
    2,026
    If this makes any sense, high performance engines demand high performance electronics. High output coils, high output voltage...wonder if your CDI is acting up? Wonder if engine get's hot, something electronic is also getting hot...not the coils, but maybe CDI? Have you changed that out? Don't know...just throwing out idears. Wonder if the alternator is not putting out enough energy when it's hot....Just thoughts.
  2. madmanncr500
    madmanncr500 Senior Member
    5,523
    125
    108
    scob ive done it all to my limits!!! cdi's work or dont work no in between!! Dyana coils on there way from ZL store!!! dont have another cdi to change it out with but like i said cdi's work or dont no in between!
  3. madmanncr500
    5,523
    125
    108
    well Dale and Mark both said there is nothing wrong with the engine! gotta be electrical!! Dale said he just re ring the engine and ran the valves before i got it! Runs good when runing other than a sputer at 3400rpm stabed! roll into it its good...jetting there!
  4. madmanncr500
    5,523
    125
    108
    :headbang: Want to thank ALL for the VEIWS and replies!!!!:headbang: when we get this all figuerd out gonna post ONE NASTY BURN OUT AND HOLE SHOT of her!!!! hopefully in front of BUDS house!!!:headbang::headbang:
  5. zlMark
    zlMark Cult Leader
    8,935
    235
    121
    :nono::nono::nono: You're gonna blow that thing up running the crap out of it without tuning the carbs!
  6. madmanncr500
    5,523
    125
    108
    like i said AFTER the zl tune shop!!!:notworthy: carbs are in the ball park she running fat now!!
  7. Scoobys_piece
    2,026
    That's what I heard..you likem FAT...:rotf: I like mine fat in the rear...bout 200mm will do...DOUGH~
  8. madmanncr500
    5,523
    125
    108
    :rotf::thefinger:
  9. madmanncr500
    5,523
    125
    108
    Like i said when i do find it it would be a duh...............DUH:fool: Last night i worked on this thing for 7hrs...got the dana coils installed with new copper core wires i made...Took carbs back off changed jets had 136 in there went with 132.....started cleaning and dioed grease every damn conector on it...got to the ignation switch(THANKS ZLMARK)..took it apart cleand and greased...BOOM BABY!!!!!!:headbang: havent got to ride it yet been raining 3 days...gonna be nice later today..... seems the ignation switch needs replaced..starts some times turn off with kill switch turn it back to run and just turns over...turn key off &on 5 or 6 time boom fires back up..... ill let all know how it runs tonight!!:headbang::goodluck:
  10. madmanncr500
    5,523
    125
    108
    Yeah it might be cold way up there but not that bad here yet....(PLUG IT IN:rotf:) U FUNNY:thefinger:
  11. madmanncr500
    5,523
    125
    108
    HOLY SH*T BOYS!!!! this thing is NASTY FAST!!!! done it!!:headbang: she is nasty fast!!! took her out for a ride to night and my GOD.... the miss is gone! was pulling front wheel off the ground in 4th!! NO more miss at 3000rpm the rejetting done the trick!!:headbang: cant wait to get this bi*ch on the track!!:headbang::headbang: shinko the real deal!!:headbang: no slip at ALL!! PULLS hard all the way thru the gears!!:headbang::evil:
  12. markus56
    3,460
    219
    Are you still thinking ignition switch or what?
  13. markus56
    3,460
    219
    I'll have a practically new ignition switch with me this weekend at the meet in case that is your problem. I've had really good luck cleaning them real good and re-greasing.
  14. Scoobys_piece
    2,026
    C? Told you....I'm smarter than most people want to give me credit for....Doesn't bother me, but I DID tell you that it was going to be something simple.
  15. madmanncr500
    5,523
    125
    108
    I knew it was something simple it always is. I'm no :pottytrain2:myself! :headbang:
  16. madmanncr500
    5,523
    125
    108
    ha wasnt the ignition switch at all!! got up to buds house for the zl event and ZLMARK,MARKUS,and I starded going thro this thing ! from one end to the next...tried the new ignition switch Markus brought for me and i thought that had fixed it. started 7 time in a row...then just cranked....back to testing Mark worked his VOODOO all over this thing...then i pull the timing cover off to check the pic up coil gap....and HEY look at that..the pick up toward the front of the engine was bent out not making good pic up:rotf: Mark bent back in with screw driver..i put her back together....STARTS EVER TIME:hello2::headbang: Now i gotta work on the carbs agin,floats out ajustment, not bad, but enuff to mess with the sinking of the carbs.....i put nasty bi*ch back together and went out did big smoke job for the crew:headbang: couple wheelies:headbang:...was really hopeing those v-wennies went buy agin with there tuff guy bikes:rotf: the guys said they had been rolling buy reving there tuff guy bikes up all day sat...nasty bi*ch was ready for them sunday...but none went buy:thebirdman: went down to the gas station was pumping the fuel when two v-winnies roll up and to my surprise they came over and was checking out the nasty b*tch...:headbang: one guy says" looks like that thing would drink gas&hauls ass"! i SAY you have NO idea!! now me being the madmann that i am:headbang: there is a BIG sweeping corner right in front of the gas station:headbang:....i drifted it with the smoke ah rolling off the back
    tire in 2nd gear:headbang: TO HELL WITH THEM V-WINNIES!!!:thefinger: I RIDE A KAWASAKI BABY!!!! OL SCHOOL!!!!:headbang:
  17. madmanncr500
    5,523
    125
    108
    DONE!! every thing done now:headbang::headbang: put pingel in tonight,carbs all done,me & madwoman went on HELL ride tonight..and WOW....nuff said...ill let the time slips show what im talking about! the first 50yards you best be in shape to hold the fck on!!!:headbang:
  18. dirtdiverkf
    dirtdiverkf Well-Known Member Supporting Member
    561
    what is hell ride? like a halloween thing? i thought about hosting a fright ride next year and end the ride at a haunted house thing or something, let me know how it went, what time of day it was, etc, would love some ideas, thanks
  19. Scoobys_piece
    2,026
    :rotf: He's got practically a pro stock bike. He was pulling a meatloaf!
  20. mudrunner88
    mudrunner88 Webmaster Staff Member Administrator Super Moderator Technical Author Supporting Member
    2,038
    26
    Yup, tried telling ya when you ordered them :laughing7: My nuts still hurt from the first hookup and then coming down and smashing the gas tank...and that was a year ago! I love them tires!
    Glad ya got it all figured out bro!
