1039cc Big Bore Kit
madmanncr500 Apr 23, 2016
  1. madmanncr500
    5,375
    47
    83
    I have a used set of pistons and cylinder that are in real good shape. Help that 9 (or 1000), make a few more ponies!!:thumbsup: $200.00 plus shipping.
  2. ZipRoar
    ZipRoar Active Member
    34
    How many more ponies and do pistons come with rods? :pk:
    473
    :hello: I think it is a WISECO 1 MM 10.5 :1 compression over bore piston kit. You do not need the rods.
  4. madmanncr500
    5,375
    47
    83
    I don't have the engine split.also the the cylinder been milled ,see http://www.zl-oa.com/community/threads/Mad-s-engine.18261! This engine broke valve springs and sent metal into the engine, it was shut down fast, no damage to the walls or the pistons, wasn't many mile on a new ring and hone job,you can still see the cross pattern on the cyl walls:thumbsup:
  5. Bozang1
    Bozang1 Well-Known Member
    1,560
    A Madmann special.... Get it while it's hot...
    It's like the toys in the movie Toy Story....it doesn't want to go back in the box....lmfao
    Seriously though, sounds like a real good deal, I'm really surprised no one jumped on it yet...
  6. madmanncr500
    5,375
    47
    83
    BUMP...Still gottem!!
  7. madmanncr500
    5,375
    47
    83
    Bump!!
  8. Bozang1
    1,560
    Can't believe you still have these...I guess no one out there wrenches anymore and wants more hp!!!
  9. madmanncr500
    5,375
    47
    83
    Its ok,someone will get them one day:thumbsup:
  10. f1nxlife
    f1nxlife Supporting Member
    1,145
    Thats a good deal, with that being said, I prefer to leave both my machines in stock mechanical trim, lest putting in a Barnett Clutch in my 1000,,and a ZRX 1200 generator . My 900 still has the original clutch at 15,000 Miles . Im sure if you Ebay them, they will sell faster. Good Luck Mr. Madd
  11. madmanncr500
    5,375
    47
    83
    :thumbsup:
  12. madmanncr500
    5,375
    47
    83
    Bump
  13. babcock
    babcock Member
    12
    Very much interested ! Please call or txt 740-5zero two 5436
    473
    :hello: Send him a PM = Conversation which is a private message.
  15. Gbrown1320
    Gbrown1320 New Member
    Still available? And if so do you have a part number? I'm trying to determine how well they will work on a 900.
    473
    :hello: Madmancr500 has not been on in quite some time. He has the cyns from a ZL 10 & Wiseco 1 mm over bore kit. I think the heads on the ZL 9 & 10 are the same.
