Pilot screws on non calif 86 zl600 and other q’s
  • Thread starter Thread starter torontobikeguy
  • Start date Start date
T
torontobikeguy
I’m reading the threads and getting that to start I gotta change the gas. My bike idles low on both prime and on so I guess the fuel switch works on both modes. But why would the revs go up when I blow in the carb vent hoses and when I turn the throttle it cuts out? The carbs and jets are cleaned but should I look at the prime screw? Where is it and how many turns out ? 3.5? Would old spark plugs cause it to sputter and die under gas ? What does the decel cable do? What are the vacuum ports for on the carbs?
You are sure you have no air leaks! In a rush but I will get back to you! Screw all the way in then Pilot/mixture screw 2 to 2 1/2 turns out!
OK where do I find the pilot screw on the 86 and where would I look for leaks typically.
:hello: Do you mean fuel mixture/air enriching screws. They are on the bottom center on the back of the carbs just behind the float bowls. Typically the float bowls O-rings leak. The floats neddle sets can wear causing the float bowls to leak.
Screenshot at 2018-08-30 14:55:21.png Screenshot at 2018-08-06 14:14:16.png My-Keihin-CVK-Carb-Settings.jpg
First 2 images ZL Manual, other image Keihin Carburretor showing parts n' adjustment they haven't changed that much in 25 years!
Test for air leaks when the bike is running, leave it ticking over, ( of a sorts), then spray over carb's a squirt of Cod/Damp start, if the RPM rises whilst not touching the Twist grip, you have an air leak!
Makes sense . I will try with wd40 to see if the revs change. I know the guy I bought the bike from put fresh seals in the float bowls. Perhaps the boots are cracked. Had me thinking that when I blew in the carb vents hoses I must have richened the mix enough for the revs to pick up. I will have to wait until later to try.
Simple problem. I had to head out with family but will update Monday
That's one annoying problem with the ZL's very little clearance under the petrol tank for good fuel line vacuum pipe runs n' HT Lead routes!
OK. I dumped the old gas in the tank. Put in fresh 91 octane. The fuel line to the petcock was kinked. I fixed it. It still only runs on choke and when I try to apply throttle it dies. but when the new fuel started to get in the bowls the revs started to hunt on idle then went up from 2k to 4k . I tried using the penetrating oil test to search for vacuum leaks. There was no bogging down so I think it's good for vacuum. All vacuum lines are connected. I'm going to take off the carbs tomorrow to take a better look. I noticed though that when it warned I heard a tin popping sound in the right muffler once so I shut the bike off . The exhaust was smoky looking when it started to rev up. Right before the pop. The engine was warm to to touch.
Valves out of adjustment will cause it to run crappy or not run at all.
I was wondering about it. I will check the manual and get a measurement tool. I gotta change the oil and plugs anyways.
Pilot jets not clean enough. Running too lean and getting 'lean hang' at idle. Need to go through again. IMO.
I don't know what vent tubes you're talking about but if the emissions crap is still attached, you should get rid of it and plug all the lines. If you don't, you'll be chasing gremlins. Mine would only start on full "choke", shoot up to 5000 rpm and die if I tried to back it off.
They're used to sync the carbs and one is also used to open the fuel valve. Cap all but that one.
OK. Now all I need to figure out is how to pull the carbs off with below freezing weather up here. Cold rubber hoses won't cooperate . Lol
