ZL600 Cafe Racer Project
Ed Mar 17, 2016
  1. Ed
    Ed Member
    60
    A friend gave me some stock GSXR rearsets so I picked up some used ZL parts (Ebay) to modify. I made mounts on the lathe and had them welded on.
    The ZL shifter splines are welded to the GS linkage arm.
    [​IMG]
    The brake shaft is in a good position so I just bent the arm out and ground it flat on top. I might weld the stock pad on later but it's fine for now, just a little chunky looking. I'm using a weaker return spring to make up for the leverage difference.
    [​IMG]
    More to come...
  2. Jarney
    Cool, keep us posted and informed on how you go about it. Later.
  3. Ed
    Ed Member
    60
    My clubmans just arrived. Other parts should be here soon.:)
  4. grooveongreg
    grooveongreg Member
    10
    what are you going to do with the seat?
    Saw some good examples on Instagram. one where a guy just bolted a flat seat with hump over the drop in the middle looked better than you would think. Another where he had like a bobber type seat. both looked okay. After I fix my (some dohnut drove it into a lamppost) tank that's next on my list
  5. Ed
    Ed Member
    60
    The clubmans won't fit in a good position without hitting the tank so I ordered some clip-ons.
    The seat will be easy. I bought a small taillight/tag mount with integrated signals and I'll form a glass or carbon cowl over it. I'll use hard foam for the passenger seat which will also attach the cowl to the pan.
    Here's a pic from the internet that I photochopped:
    [​IMG]
  6. madmanncr500
    5,362
    12
    I like it!!:headbang:
  7. Jarney
    That's not bad looking at all. Hope it all goes well. Later.
  8. Drdeth
    Drdeth New Member
    11
    How is the seat to peg measurement, can you sit and put yer feet on there without cramping up?
  9. Ed
    Ed Member
    60
    It's very cramped but I have a seat to modify.
  10. Ed
    Ed Member
    60
    Guess which 4 into 1 this is...
    [​IMG]
  11. Ed
    Ed Member
    60
    Reposted missing images...
    [​IMG]
    [​IMG]
    [​IMG]
    kawboy, R. J. and Harriminator like this.
    6,671
    113
    108
    :hello: Nice. :notworthy:.
  13. 87kawzl
    87kawzl Well-Known Member
    953
    27
    Great looking scoot!
  14. Ed
    Ed Member
    60
    I put the 4 into 1 on until I get the headers rechromed. There's a problem with the carbon contaminating the bath so it might be a while until I can seal them up.
    The bike is in near perfect shape so it's hard to continue with this project without spare parts to modify. I'm considering getting rid of this bike and buying a 2018 CRF450RX for the ultimate cafe racer project.
    It's gonna be hard parting with the ZL because of it's age and conditon.
  15. Ed
    Ed Member
    60
    The plastic on the stock radiator guards were too close to the headers so I found these from Givi that were removed from an XSR700. They just happen to have the right hole spacing. :)
    [​IMG]
    6,671
    113
    108
    :hello: Nice. :notworthy:. What is a XSR 700.
  17. Harriminator
    485
    37
    113
  18. Ed
    Ed Member
    60
    Sorry, I see it's stock and not a Givi.
