Water pump advice
pipnow58 Nov 29, 2017
    6,629
    108
    108
    :hello:I keep the spare pump.
    6,629
    108
    108
    :hello: So did you decide on what you are doing. It's to late to cancel your parts that I orderd.
  3. pipnow58
    pipnow58 Active Member
    99
    My son want's to check out the ebay pump when it arrives. It might be bad also. I have been dissecting the old pump . I pushed out the shaft, there was no snap ring. Does the bearing and seals push out toward the turbine ? I tried to push both directions, seems very tight. I don't want to destroy anything.
    6,629
    108
    108
    :hello: Yes they are hard to press out. It's best to use a press. They push out from both ends from the inside. The inside bearing is always bad.
  5. pipnow58
    99
    I have a feeling the pump was rebuilt before as there was no snap ring. They either lost it or forgot. the impeller is good and tight, no play
    6,629
    108
    108
    :hello: Are you talking about the one off the bike or from E-bay. Does it have a grove for the snap C-ring. Some pumps have them & others don't. Even from the same year/model. Clean up all the rust on the shaft. Also when installing the new oil seal put a thin bead of black RTV around the inside rim of the water pump before installing the oil seal. I've seen new oil seals pop out. One other thing after installing a water pump coolant may drip from it. Don't be alarmed. Start & run the bike. Bring it up to temp. Then let the bike get stone cold. Then check for leaks. I was told from my friend Ron A. who is a retired KAW Tech that if some coolant is left in the system after being drained it will find it's way down hill & get into the water pumps back side of the mechanical ceramic seal presenting a faulse leak.
  7. pipnow58
    99
    The pump removed from the bike had a groove but snap ring was missing
    6,629
    108
    108
    :hello: I need to reword the part on the mechanical ceramic seal of post #26. It is possible for coolant to weep out before the bike is started because the ceramic seal needs to be seated & this happens after the bike is warmed up. This refers to a pump that has been opened up.
    6,629
    108
    108
    :hello: pipnow58: The parts for your son's 87 Ninji 750R came today. Let me know if you need my Services. If not it's no big deal. Most of these parts will fit other water pumps.
  10. pipnow58
    99
    Thanks for all the info and help. I have been rebuilding 70s era bikes all my life but I don't know as much about water cooled kaws. I can bring a 75 Z-1 900 back to life and make it as good as new, love those old 900s. I should know about the pumps by early next week or sooner
    6,629
    108
    108
    :hello: I inventoried my parts last night. I compared the ZL 9 & 10 water pump parts to the 87 750R Ninji's. Some of the parts have different part #s but all the parts are all the same.
