Removing coolant manifold: How to?
BearHunter Jan 4, 2018
  1. BearHunter
    BearHunter New Member
    Hi,
    I noticed a leak of coolant in the front of my ZL900 engine. After removing the radiator and exhausts, I find it's the manifold that leaks (cylinder 1 and 4 from left to right). I want to replace the 16mm O' rings.
    I disconected the hose but the manifold don't come out. It's stuck there.
    How is it supposed to come out?
    6,671
    113
    108
    :hello: This section is for the 125 & 250 Eliminators. To answer your question. Wrap your coolant pipe with some rags at each end & one around a small pry bar. Gently pry the pipe ever so slightly a little bit at a time on each end. Go left to right a bit at a time.
