Relays & Switches
JohnB Dec 10, 2017
  1. JohnB
    JohnB New Member
    10
    I am looking for the following parts for my 19858 ZL 900;
    Fan Relay - 27002-1054
    Fan Switch Relay - 27002-1055
    Fan Switch (97c) - 27010-1180
    Fan Switch (110c) - 27010-1188
    If you know of equivalent/replacement part numbers please advise.
  2. prfixer
    1,246
    15
    Ebay has the first 3 in quantity
    6,671
    113
    108
    :hello: The one that goes on the bottom center rear of the radiator you can buy new OEM for @ $80.
  4. JohnB
    JohnB New Member
    10
    Thanks for the replies; I will look into these sources.
  5. SandstoneSmitty
    SandstoneSmitty Well-Known Member Supporting Member
    664
    Did you find your Relay and switch? I may have some new/used ones in my parts bucket I will let go cheap. Years ago my beloved 'Lil Girl' (86 ZL-900) was possessed by a ghost: Fans would go off and on without the key in ignition. I started with relays and switches. The problem was that the gas tank had rubbed a hot short into the cooling wiring. Months of debugging and 5 cents of electrical tape fixed the problem. The results is that I have parts that I do not need.
