I really hope that the fuse box was your problem.
Man that sucks!!!Sorry to butt in but, my experience with pick up coils is that when they go bad, they work fine until they get hot, then conk out. Same with CDIsThanks RJ, I bench tested the pickup coils and they were good, I will get your check in the mail tomorrow. Bought a brand new battery and fired up fine...then dies. Fed up. What could be progressively dying, first it was @ cruise speed rpm cutout, then runs till it's warm then dies wouldn't restart but would fire on jumper box. Now good battery fires right up good throttle response but dies before fully warmed. I think it is pissed about the road king and is destined to sleep in the back of the shed and forgotten about
Might be a good idea, I have experiences with both cdi's and pickup coils that would work fine for about 5 or 10 miles and then stop, then after cooling down would work fine again for 5 or 10 miles.You're not butting in at all. It sure does seem electrical. I think i will clip onto the coil pickup hot wire and see how it behaves while it is running and then dying.
The dumb way. I replaced the CDI and if that didn't fix it, then the pick up coils.How did you diagnose which one it was that was causing the issue?
RKERG: Which one ended up being bad. Can the bike run with the pickup coils cover off. If so do the ice pack treatment. Duck tape a bag of ice to the pick up coils and ride the bike. I done this a few times with other bikes. Another thing you might have a weak ground in your wiring harness. The ZG 1000 fourm SHOULD Of BEEN ENGINERING tells his guys to run a short ground wire from the CDI/ECU to the frame right next to the ECU. He says it will make the bike run better. It wouln't hurt. One other thing. You can also duck tape the ice to the pickup coils cover. https://www.google.com/search?q=sho...ing+adding+a+ground+wire+from+the+ECU+to+the+ .Hey RJ. I am still using that water pump that I got from you. Anyway, I have had to replace both my CDIs and my pick up coils twice in the 20 something years that I have had my 900. I got both cdi's used on eBay and got one of the pick up coils from a member and another was a new after market one. The thing about the used cdi's is that you don't know how long they will last and that's why I started taking a spare with me while riding. Take care and stay safe.RKERG: Which one ended up being bad. Can the bike run with the pickup coils cover off. If so do the ice pack treatment. Duck tape a bag of ice to the pick up coils and ride the bike. I done this a few times with other bikes. Another thing you might have a weak ground in your wiring harness. The ZG 1000 fourm SHOULD Of BEEN ENGINERING tells his guys to run a short ground wire from the CDI/ECU to the frame right next to the ECU. He says it will make the bike run better. It wouln't hurt. One other thing. You can also duck tape the ice to the pickup coils cover. https://www.google.com/search?q=sho...ing+adding+a+ground+wire+from+the+ECU+to+the+ .
The other sideThe after market pick up coil works but, the rubber grommet doesn't fit the opening tight enough to prevent some of the oil from dripping out. PIA. I opened this CDI a long time ago out of curiosity.View attachment 48257
I opened up a CDI unit. It's completely sealed in conformal coating. You can buy a remover for it but I've never tried it.
This WELLER solding iron is my best one for PWB. VAMPIRE solder sucker. I've had others. This is the best one of all. Copper solder transfer wicks.
