Knee Guard Dampers
Breeze Jan 11, 2018 at 10:50 PM
  1. Breeze
    Breeze Active Member
    34
    I have an '85 900 and the knee guard dampers on the rear of both knee guards have separated. On side is steel and the other side is rubber. I need to repair these to get the bike ridable again. However, I'm a little worried about using the wrong adhesive/epoxy and that they just fall apart again or look terrible. It looks like the left side may have been repaired once before, but that was over 25 years ago because I have owned the bike since '92 and I have never needed to mess with them until now. Does any one have any advise for the best stuff to use?
  2. prfixer
    1,246
    15
    Gorilla Glue worked for me.
  3. markus56
    2,826
    59
    93
    You can always use a good rubber cement and then drill through the damper and secure with a nut and bolt.
  4. Ducky Dog
    Ducky Dog Member
    64
    The Steel to rubber Damper you say?
    I have repaired a few similar items with good quality Super Glue
    remove the part, acetone them and clean them, apply Super Glue and clamp in a Vice.
    not too tight,, just enough pressure to hold them together, let set for an hour or so.
    Also rubber turn signals can be repaired with the same method
